Authorized access to a erp server
I am applying RSA using VPN client to give authorized access to a public erp server over internet.
How can I will be able to allow access to particular users using above technology or any other?
Whatsup Aboni, You can be able to access the users by configuring the network and the connections to ensure all the users can be reached.
Ensure you have the user profiles that can be accessed by the users
Have the correct username and password for authentication of the network
Configure the file connection parameters such as enable log which determines when to override log settings for the classes that use logging services.
With all those procedures, you can test whether it can now access the users, it should work.
Thanks
Notifications
