Auto Clutch Test exe Application error
I started an installation with the 2010 run time engine and ran the installed program but unfortunately got this weird error gift. How can I fix this problem? What is cause of this error message? I just need some resolutions. Thanks.
Auto_Clutch_Test.exe – Application error
The instruction at “0X7c911669” referenced memory at “0X6e75533a”. The memory could not be “read”.
Answered By 590495 points N/A #174284
Whenever you receive this kind of error in any program you might have on your computer, don’t get scared. Normally, it’s just an unexpected error that happens when starting a program or closing a program and it sometimes appears when Windows is shutting down. Normally, an error like this can be fixed by simply restarting the computer.
But if you see this error constantly every time you start your program and your program doesn’t open, make sure you meet all the requirements. If this is a fresh installation, check if your operating system is supported as well as other requirements. If you just install the application without checking first the specifications then you should do so.
Open Windows Explorer and navigate to the installation folder of the application and open the “readme” file. It usually lists the specifications of the program. But if it’s not there, open your web browser and visit the official website and check the system requirements of the version you have. You cannot make a program work and you cannot use it if it doesn’t support your operating system or it is missing several required software.
Another way of fixing it is to upgrade it to the latest version in case you are using an old version. You can also upgrade your operating system to Service Pack 3 if you happen to be using Service Pack 2 and earlier. Microsoft already ended support for Microsoft Windows XP and you should have the latest Service Pack to have the latest and last update for the operating system.
