Auto It error opening the project parcours
AutoIt the requested action with this object has failed with this error. This kind of error started to appear recently and I don’t have any idea to manage this. Is there an online expert that can help me please to fix this error ?
Thank you !
AutoIt Error
Line 9698 (File “C:UsersZ-BarreDocumentsParcours sirensParcours
Sitens InetGet.exe
Error: the requested action with this object has failed.
Answered By 590495 points N/A #179549
You caught this error because the AU3 script you loaded has a problem in line number 9698. I guess the script has a certain action on an object or a file in particular that when executed failed to complete or simply failed. Check that line number indicated in the dialog box to properly check the error.
If the action supposedly will launch a program, make sure the path of the executable is correct. I guess the task or action will execute the file “parcours sirens InetGet.exe” which is located in “C:UsersZ-BarreDocumentsParcours sirens”. In case you can’t find a problem in the script, try loading a different script to see if AutoIt runs it normally.
Also, if you are using an old version, you should update to the latest version. Download and upgrade to AutoIt 3.3.12.0. It requires Windows XP, Windows Vista, Windows 7, and Windows 8. You can also use it on Windows Server 2003, Windows Server 2008, and Windows Server 2008 R2.
