Auto It errors with Au3 type extensions
Hi there,
When I want to open .au3 extension this error appears. The program has full compatibility with this type of extension and still. Can anyone help me please to fix this error ? Is this type of extension not compatible ?
Thank you !
Autolt Error
Line 16 (File “E:z_PERSONALAutoIT#IT.au3”):
AU3RecordSetup()
Error: Unknown function name.
Answered By 590495 points N/A #179570
AU3 files or files with “.au3” extension name are automated script files created by AutoIt version 3. If you install AutoIt using the full installer, you can execute an AutoIt script by simply double-clicking the file. So, if this error appears as a result of double-clicking an AU3 file then there is probably a problem with your AutoIt program.
To make sure you have the latest version, download and install AutoIt 3.3.12.0. It requires Windows XP, Windows Vista, Windows 7, and Windows 8 as well as Windows Server 2003, Windows Server 2008, and Windows Server 2008 R2. Once the latest version is installed, you can start “it.au3” by double-clicking on it. AutoIt will automatically open and run the script.
Aside from double-clicking on the AU3 file to execute the script, you can also open it within AutoIt. When you start AutoIt, the application will ask you to open a script file. Here, select your “it.au3”. To learn more about compiling AutoIt scripts, do visit Running Scripts.
