Even for modern freelancers & article writers it's a bad issue, that normally one can't afford costly article batch spinning software.
So i wondered whether there are any free services available there in the internet for jumbling & producing a new unplagiarized content out of the submitted articles.
Any tips, links on finding such websites.
Auto online spin article Services
Hi Harry Ggaston,
I have viewed some forums that are discussing this matter.
There are a lot of informative posts there that may help you find the best solution for your concern.
Kindly click the links below:
Supreme Article Spinner One Click AUTO SPIN Nested Spin Get 500 unique articles
SpinProfit Free Article Spinning Service
Hello Harry,
There are numerous spinning tools available online, while some are free others are not.
You may consider using SpinBot, Spin Rewriter, SpinProfit. While all of them are extremely good at spinning original content, it is very important to keep in mind to not to submit the content generated by them without reviewing or proof reading the generated content.
In case if you are not satisfied with the features in the above tools or would like to have something that is not available in them, you could even consider developing your own spinning application, a good start would be by looking to an earlier post made by me in response to a previous request wherein I have given some sample code snippet too.
Hope this information helps you.
Mclean Buono
