Auto Running Automation with exe
Morning, I just download AutoIt software, from the review its the simples scrip for Auto Scripts. I want to use it to do some Automation with exe for my software. What are the codes do I use to make it happened? I really new with all this, forgive me. Noob.
Answered By 0 points N/A #168458
Hello Rain,
AutoIt is a great program and you can do many things with it. First though, you will need to learn how to create some scripts. I have found some sources where you can read some tutorials and see some example scripts on how to do some things.
Here is the wiki page of AutoIt which have some great tutorials: https://www.autoitscript.com/wiki/Tutorials
Also, after reading the tutorials and learn your way around the software you will need to see this forum to get known with some sample scripts: https://www.autoitscript.com/forum/forum/9-autoit-example-scripts/
P Vhilary
