AutoCad 2000 Won’t work !!
So recently whenever I opened AutoCad 2000 map the following error occured "FATAL ERROR: Unhandled c000096h Exception at 132c6ach " So what should I do ? Really need help!!
Try to follow update present punish a “Fata Error” that occurs arbitrarily during running the program. “acdb17.dll“
This error borne usually through an “Auto Save” or an express forbear of a draftsmanship. The trouble occurs arbitrarily, mainly frequently when using Autodesk Civil 3D 2007, or Autodesk Land Desktop 2007, and Autodesk Architectural Desktop 2007. It is celebrated to become when using additional products on the inclination on top of as recovered, but inferior often.
The additional entity that can effort this, is “Hardware Problem”. It happens when for example you add another physical RAM, and some time your draftsmanship gets larger the coating is meeting stopped. So you can try this too if you have added any new hardware with your.
