I have been working with some engineering drawings for my client's requirement but recently I am getting in touch with some international client and they want me to work with some upgraded version for AutoCAD I am using older version I have been looking for AutoCAD 2010 for 64 bit windows 7Â version .How to get that software application please provide me some reference over it
Hello Grant,
Over the years AutoCAD has been a major leader in 2D and 3D CAD architectural drawing and also engineering. The latest service pack being offered by AutoCAD is 2013 which you may want to have a copy just in case you come across another client who might prefer you using another version higher than Auto CAD 2010. But for the purposes of your current client you might want to have a look this particular AutoCAD 2010 version at AutoDesk website and purchase the particular upgrade. They offer a support services and you will be able to the version that you require.
The link is as and click on the link AutoCAD2010 to be able to purchase a copy.
All the best.
