AutoCAD 2010 Installation has encountered an error
I am getting this error message after I install the AutoCAD 2010 64bit in my laptop. The application was unable to start correctly (0xc000007b).Click Ok to close the application. Can you please help me to fix this problem? The following error message is shown below which will guide you to find relevant answers. Thanks for any help.
I am getting this error after I install the AutoCAD 2010 64bit in my laptop using Windows 7 Operating System. Can you please help me to fix this problem? The following error message is shown below which will guide you to find relevant answers.
Acad.exe – Application Error
The Application was unable to start correctly (0xc000007b).Click ok to
Close the application
