AutoCAD 2012 Install Failure, please help!
Hi all,
Will DirectX11 and AutoCad ´12 work together or compatible? Because it seems that I am having problems. I have attempted to reinstall them, installing them in different orders and using a visual´10 pack. AutoCad just won´t install runtime for some reason. Any help is appreciated. Below is the problem.
Installing DirectX Runtime: C:AutodeskAutoCAD_2012_English_Win_64bit3rdPartyDirectXDXSETUP.exe /silent
2012/4/2:19:03:03 Caleb KALEB-HP Install DirectX Runtime Failed Failure is ignored, Result=-21
2012/4/2:19:03:03 Caleb KALEB-HP Installing Autodesk Material Library 2012 – Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:AutodeskAutoCAD_2012_English_Win_64bit" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/2:19:05:28 Caleb KALEB-HP Install Autodesk Material Library 2012 – Low Resolution Succeeded
2012/4/2:19:05:28 Caleb KALEB-HP Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:AutodeskAutoCAD_2012_English_Win_64bit" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/2:19:05:40 Caleb KALEB-HP Install Autodesk Content Service Succeeded
2012/4/2:19:05:43 Caleb KALEB-HP Installing AutoCAD® 2012: TRANSFORMS="C:AutodeskAutoCAD_2012_English_Win_64bitx64en-usacadacad.mst;C:UsersCalebAppDataLocalTemp_AI2DE2.tmpx64acadacad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:AutodeskAutoCAD_2012_English_Win_64bit" INSTALLDIR="C:Program FilesAutodeskAutoCAD 2012 – English" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/2:19:06:01 Caleb KALEB-HP Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2012/4/2:19:06:11 Caleb KALEB-HP Rollback Autodesk Content Service Succeeded
2012/4/2:19:06:28 Caleb KALEB-HP Rollback Autodesk Material Library 2012 – Low Resolution Succeeded
