AutoCAD Facing Unhandled E06d7363h Exception Error
I get an unhandled e06d7363h error when launching AutoCAD. Can anyone give me a quick solution for this issue? It would help me out of this situation.
The unhandled e06d7363h common error that everyone faces with AutoCAD. The solutions to this error are simple:
• Right-click on the software icon on your desktop and go to properties.
• In the properties section, click on advanced. Now it will load a new window.
• In this window, tick on the box where it says RUN AS ADMINISTRATOR. Now press OK and Apply.
• Now open your software and check if this solution worked or not.
If the previous one didn’t help you out in fixing the unhandled e06d7363h error, try this:
• First, backup all your projects from that software. Uninstall and reinstall the software.
