I upgraded to AutoCAD 2013 yesterday and I suddenly find myself pestered by a silly pop up message. I tried to assign a pallet orientation to Quickcalculator on the CUI editor and then save my workspace and exit. I tried launching AutoCAD again and I get the unhandled exception shown below. This error occurs irrespective of the left or right pallet orientation assigned. If try to click continue, Quickcalculator is no longer docked and it floats around. I have never seen this happen in AutoCAD 2012. I tried resetting AutoCAD to default settings and tried to recreate the scenario. And I still get this error. I undocked the Quickcalculator from my workspace. But this too did nothing to improve my situation. What is causing this annoying error? Does anybody have a fix for this issue, please? I am all ears. Thanks in advance.
Error:
Unhandled exception has occurred in a component in your application. If you click continue, the application will ignore this error and attempt to continue.
Width and height must be non-negative.
AutoCAD fails to launch with an unhandled exception
Hi Xavier,
The error is due to the incorrect application installation files for AutoCAD software.
To resolve this error follow the steps as stated below:
1) Click 'Start', select 'Control Panel'
2) Click 'Settings' option from the list
3) In the control panel, select 'Add/Remove Programs' option
4) Select the AutoCAD 2013 software from the list of software
5) Click 'Change' button on the software in the system
6) Select the option to repair installation and complete the steps provided in the system
7) After the process is completed, restart the AutoCAD installer in the system
Try to uninstall and reinstall the program. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select your AutoCAD among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, close Revo then install AutoCAD back. If this doesn’t work, try starting the program as admin. Right-click AutoCAD then select “Run as administrator”. If this works, set the program to always run as admin. Right-click AutoCAD then select “Properties”.
In the “Properties” window, go to “Compatibility” tab then under “Privilege Level” section at the bottom, check “Run this program as an administrator” and then click “OK”.
