AutoCAD FATEL Error in windows
when I try to run AutoCAD on my system (windows 7 32-bit) it automatically stops working by saying the following error and quits working. I don’t know what is the possible reasonbehind and how can I resolve it?
AutoCAD Error Aborting FATAL ERROR: unhandled Access Violation reading 0x0021 exception at e7c00da3h
Answered By 0 points N/A #198184
Hello Dear Tatyanamaiaa,
Thanks that you have shared your problem with us.
Dear it seems that you have installed the AutoCad missing some options and files.
You did not have installed it properly. Kindly check your installation package first. And also make sure that you have not missed any file during installation.
I suggest you to reinstall the software. But please make sure first that you have 512MB RAM and minimum 1 Ghz Processor.
Thanks
