AutoCad LT WHIP failed to initialize
I am trying to install WHIP setup but the setup is not initializing. An error occurs due to this effort which you can see in the below attached image. Need assistance please
WHIP failed to initialize.
Hi there
I have read your problem and this may be because you having older graphic card which does not support the version of AutoCAD you installing. The below picture will show you the requirements for installing AutoCAD 2013 on Mac:
For AutoCAD 2013 (Mac):
– Apple Mac OS X version 10.6.8, OS X 10.7.2 or later, OS X 10.8 or later with 64-Bit Intel Processor.
– Apple Mac Pro 4.1 or later; MacBook Pro 5.1 or later (MacBook Pro 6.1 or later is recommended); Mac Mini 3.1 or later (Mac Mini 4.1 or later is recommended); MacBook Air 2.1 or later; MacBook 5.1 or later (MacBook 7.1 or later is recommended).
– You need at least 3GB of RAM (4GB is recommended)
– 2.5GB free disk space for downloading and installing the software (3GB is recommended).
– Supported hardware for graphics card.
– 1,280 x 800 display with true color (1,600 x 1,200 with true color is recommended)
– Mac OS X supported language OS
– Apple Mouse, Magic Mouse, Magic trackpad, MacBook Pro Trackpad or Microsoft compliant mouse
– Mac OS X compliant printer
If your pc having these requirements try installing a different version of AutoCAD
Best of Luck
Taylor B Campos,
Thank You
Notifications
