After Updating my Autocad Mep 2009, it is having some problems. After the update when I exit Autocad Mep 2009 and open drawing file from server, Autocad crashes down and shows error "Fatal Error: Out of memory – shutting down"
This is not a good sign for me.
Autocad MEP 2009 Fatal Error
It happens when you exceed the physical memory's limit. That happens with big drawings and all. Reduce the size of your drawing and you will be fine with it. As the error itself suggests- out of memory. That happened in Autocad previous versions. I think you must upgrade to a newer version or search for a patch and you will be fine with the error. Autocad have fixed the problem now with the error : out of memory.
Cheers.
