King Lopezs
30 points
Posted on - 10/19/2012
Hi Experts,
While installing AutoCAD MEP 2012 on may machine I received an error message.
It is indicating an error 1402 i.e. failed to open a key as I have not sufficient access to that key.
Have a look at the screenshot below.
Have you any idea for the issue?
Please help.Â
Thanks in advance.
AutoCAD MEP 2012
Error 1402. Could not open Key:
UNKNOWNComponents133B062FD83CDF84BAAA82C213E6A0EE7D2F3875600A9040102000060BECB6AB. Verify that you have sufficient access to that key, or contact your support personnel.
AutoCAD MEP 2012 Error 1402. Could not open Key:
Hi King Lopezs,
I have researched some possible answers for your concern and I think the Link below would be the best solution for this matter. Kindly click the link below and make a reference.
Could not open Key: When installing/uninstalling ACAD MEP 2012
You may also like to join the discussion in this forum:Â
Ask the Expert
Thanks and More powers.
Solutions for error 1402 for both uninstall and install cases are the same, based on the Autodesk Support website. You will need to access the registry editor for this to be resolved. You would need to go to Start>Run then type regedit.exe and press enter for Windows XP, while for Windows Vista and Windows 7, you would go to Start> then type on the "Search programs and files" bar regedit.exe.
Once the registry editor is open, locate the "HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionInstallerUserDataS-1-5-18Components" directory, right click on the "Components" folder then click on "Permissions". Go and click on the "Advanced" button, and under the "Owner" tab, go to the "Change owner to:" selection box, and select the user group "Administrators" then click "Apply".
After that, select the check box "Replace owner on subcontainers and objects" and click "Apply". Afterwards, click on the "Permissions tab", then click on the check box option "Replace all child objects Permissions with inheritable permissions from this object" then select apply.
Please take note that actual wording may differ depending on the operating system you are using.
