My current problem is that in AutoCAD and Revit Structure 2012, when printing to the KIP 3000, if I click the properties button to the right of the printer name I get an Unhandled Exception Error and the program crashes and closes.
How do I fix this?
Autodesk Revit
Autodesk Revit has encountered a problem and needs to close. We are sorry for the inconvenience.
AutoCAD Revit has encountered a problem
Hello Jayce,
That is an issue most probably due to viruses that are affecting system and the resolution you will need to use is the following:
• Using the antivirus that you have on your computer, scan your system for viruses. If you can be able to remove the viruses that will be found, do that.
• If you can't be able to remove them, you will need to format the computer and the reinstall AutoCAD.
Nicke
