I have installed Windows Vista and I wanted to use Google Earth Extension. So my question is, is Google Earth compatible with Vista? I am asking this because I was getting an error whenever I tried to load Google earth extension into AutoCAD Map. I need help in solving the error below.
Error image:
Image message :
Write permission denied. Unable to create CProgramFilesAutoCAD Map 3D 2010GoogleEarth.cui
AutoCAD shows error, says write permission denied
Google Earth extension is no doubt compatible with Windows Vista and other Operating Systems as well.
One thing you have to follow is to check out if your OS X is 32-bit or 64-bit, because AutoCAD 2007-2010 versions are 32-bit only.
If your OS X is compatible then, go on to solve your problem following these steps:
Go To Control Panel > User Accounts > Click User Accounts again > Turn User Account Control On or Off > Press continue on warning message > Uncheck Use UAC to help protect your account.
This would probably solve your problem.
