AutoCAD suddenly encountered with an error message
Please help me. Whenever I am trying to save specific format in AutoCAD this error message appears. Please explain me how to solve this issue?
he operation was not no file was created.
AutoCAD Message
One or more objects in this drawing cannot be saved to the specified format. The operation was not no file was created
Answered By 0 points N/A #175713
These are three possible solutions:
1. Try freeing up space on the file server. The error should go away and you should be able to save your drawing. This is because there have been reports that this error occurs when space on the network server runs out as you try to save a drawing there.
2. If it doesn't solve it, try checking your Ethernet adapter drive to see the TCP Offload setting and disable that feature. The network card setting may also be a cause of this error.
3. Lastly, you might have renamed the document using "saved" as a command. This can cause the error. Try to use "save as".
