Autocad video looping back to the start
I made a video with AutoCAD. But the video has no sound and it keeps on looping back to the start after 3.20 minutes. why does this happen?
If you still have the video project you created in AutoCAD, open it again then check the settings of the video. It is possible that you enable a video-looping option on its settings. The video-looping option is commonly used in creating a DVD video. In DVD, if this option is enabled in the video editor, after the video is burned on to a DVD disc, when the DVD video disc is loaded in a DVD player the video will just keep on playing every time it reaches the end of the movie.
You may also check the settings of the video player you are using on your computer. Sometimes there is an option in some media players that allows a video to be looped when it is played so it will just keep on playing every time it ends.
