AutoCAD viewer converter Mac (dwg to PDF)
Hi All,
I would like to have an AutoCAD viewer converter Mac that convert the dwg format file into PDF and that will be in a viewable format, without the support of AutoCAD in Mac OSX. Please do the needful for suggesting the mentioned converter, which can be available for free of cost.
Thanks,
Arthur W Adams
Answered By 0 points N/A #128859
Hi Arthur. I can help you with regards to your problem. There is a software called Microspot DWG viewer. You can search it from the internet. It enables you to open AutoCAD DWG files that you created from the windows to be able to open and view on MAC OS X. You can choose whatever layouts you want to open. It can also convert the drawing format file to PDF which is in a viewable format. I hope this information will be of great help to you.
