Autodesk 3ds max 2011 error
While opening Autodesk 3Ds max, it closes unexpectedly and in view report details,it says:"the error report contains the following files: 3dsmax_minidump.dmp dmpuserinfo.xml dumpdata.zip" what should I do????!!!!!
Hello!
This is an often encountered problem among the users of Windows 7, so you might want to try modifying the compatibility. First make sure you are in the administrator mode, then right-click on the program icon, go to Properties, check the "Run in compatibility" box and then try selecting what type of Windows you are using. You can still try to select other types, such as Vista instead of Windows 7 and vice versa.
If this doesn't work, I'm afraid you'll have to try uninstalling and reinstalling the program again. Don't forget to clean the registries after you uninstall it, preferably using a specialized software like CCleaner.
There might be a problem in compatibility between your operating system and the program, both must be either on 32-bit or on 64-bit, not one in 32 and the other on 64, although for this kind of software it is better to use 64-bit programs.
Then again, the internal memory of your computer might not be enough, case in which I suggest buying some extra RAM to improve the capacity of your PC. Or it could be the graphic card or the display driver, it happens when they are outdated and can't keep up with the program's requirements.
I hope you solve your problem as soon as possible!
