Autodesk 3ds Max design error
I was in the middle of my work opening and closing files then in one work that I was doing this just happened. It didn’t just happened once, in a day almost 3-4 times and sometimes my work can’t be saved. How do I prevent this from happening so that I would be more productive?
3ds Max application
3ds Max application has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available
