Crewe Bob
30 points
Posted on - 08/21/2012
Can someone please explain why i am getting this error and how can i solve this?
I am using Autodesk Data Management Server Console 2012.
Error message: An error occurred when applying configuration. See the log for detail.
Autodesk Data Management Server Console 2012 Error.
Hi Bob,
First of all thanks for posting a problem.
I get pleased when I can solve a problem. It may be any difficult or simple. But difficult problem always gives different pleasure.
Anyway, from your image posted above I can see that there are duplicate rule names. Please check all the rules and make sure that there are no duplicate rule names.
I think your problem will be solved.
Hathy
