Autodesk dwf toolkit on Android
I am using iPad 4 and would like to know whether there is an Autodesk dwf toolkit on Android, that will help me to do small editing and corrections in AutoCAD dwf files, If there is any such toolkit, please do the needful for suggesting the same. Ensure that it is compatible with iPad 4.
Answered By 0 points N/A #180750
There are many Autodesk DWF Toolkit applications for Android. I like the Autodesk Force Effect application the best.
Autodesk Force Effect is a mobile engineering application which helps you view and edit your Autodesk design. You can email, print, or give a report directly from the application.
You can simulate and calculate on your Autodesk design as well. Download it here.
Now, download and enjoy it on you Android.
