Autodesk Education Suite installation stopped, saying Cabinet file required
I was attempting to install the Autodesk Educational Suite for Entertainment creation 2011 on several Windows 7 pcs .Using the same install files on every computer (located on local hard drive), it works fine for all but one system. On this machine I get the error that a required cabinet file for installation is corrupted. I tried disabling the antivirus software installed temporarily and then installing Autodesk Educational Suite, but still this error persists. Is there a work around to resolve this issue? Or is this a system specific issue? Does anyone have any ideas regarding this issue? Please share. Thanks in advance.
Error 1335. The cabinet file ‘Common~1.cab’ required for this
installation is corrupt and cannot be used. This could indicate a
network error, an error reading form the CD-ROM, or a problem with
this package.
