Autodesk Entertainment Creation Suite 2012 error
I have installed the “Network version of Autodesk Entertainment Creation Suite 2012” and it’s showing me a message given in the screenshot when opening it. Can anyone give me a solution here?
unable to access a license,
"A valid license could not be obtained by the network license manager.
If you are still unable to access a license, contact your system administrator
Error [0.0.0]"
Answered By 0 points N/A #176214
Hello Carlos,
The error message you’ve mentioned it happens only because of bad license. To get over from this you need to verify a few things. At first you have to make sure User Account Control Settings (UAC) are turned off in users' machines. Secondly you have to verify about the current LM Tools installed on your Server and its set up correctly. If you are facing problem in installation you can check out the site “How to install or upgrade the Network license manager”. After that make sure your license file is correct then you can easily run it in the Autodesk License Parser to assure the information is correct. If you have no idea where to find the information you can find it in your LMTools on the System Settings Tab. By emailing Autodesk at autocodes@autodesk.com you can submit for a new license.
