I was working in my Autodesk when this error popped out of nowhere.
How do I fix this?
Do I need this fixed immediately?
I don't know if this would affect my work.
Error
Loading failed with error 126: the specified module could not be found.
Dennis
Autodesk Error: Load Library failed with error 126
Hello Dennis,
It appears like ATI OpenGL support is near non-existent. If you haven't tried using an earlier Catalyst version or uninstalling, or also rebooting and then reinstalling the latest Catalyst version you will need to try that.
The steps illustrated in the following link may also be of great use in case the above resolution does not offer much help: Does anyone have a working ATI OpenGL driver DLL? – Blender Artists Forums
Carl
Check if you are using X64 based system. Go to the Command prompt and run the computer in administrator mode. Now type the following command: c:\windowssystem 32copy atio 6asxx.DLL.DLL. You now need to restart the computer and again look for the issue. Hope this will solve your problem.
Waters Magner
