I am shocked because I paid a lot of money for the Autodesk and now I cannot activate the program. I think I might lost the license because I entered many times and all the time I had the same error. Any solution ? Is there another way to activate the program ?
Thanks !
Autodesk Licensing-Activation error
Registration- Activation Error (0015.111)
There is a problem with the activation code that you entered. Click one of the following links.
Autodesk Licensing Activation error appeared
If you already paid for the Autodesk product you are installing then you don’t have to worry. You can always request for a new serial number as replacement in case the one you have really doesn’t work. This problem really happens and cannot be avoided. When registering and activating your copy, make sure you enter the code exactly as it appears.
If the code has a dash in between numbers then put a dash. Make sure also that the code you enter doesn’t contain a space because serial codes doesn’t have a space. If the serial code for the Autodesk product was sent via email, just copy and paste it on the interface to make sure no characters will be entered incorrectly.
If all attempts failed, contact Autodesk and ask for a new serial code as replacement and explain the problem.
