Autodesk Moldflow Advise cause of a security failure
I have this error when I want to run Moldflow 2012. I meet all the system requirements and all the requests below and still I cannot run the program. Can anyone help me please to fix this error ? What could be the problem ?
Thanks !
A security failure has occurred. Check the following-
You are using the correct license server.
You are isung an appropriate version of product security.
(The installation guide will specify the appropriate version of product security to use.)
The license server has valid licenses installed.
You can access the license server.
Release – Autodesk Moldflow Advise 2012 Service Pack 2 – barium_main_sp2
Build – 11271-001
Platform – x64
Serial Number – 000-0000000(Autodesk Moldflow Advise Advanced 2012)
Operating system – Windows 7 Service Pack 1
Graphics – AMD Radeon HD 660 Series
Language – [English, 11271]
You can go to the Autodesk Moldflow Website to get more information on how to solve your problem. To do so, you will need an internet connection.
Would you like to go to Autodesk Moldflow Website?
Yes No
