annie brown
20 points
Posted on - 05/10/2012
Hello! I have installed Autodesk Network 2012 with the help of Creation Suite and got several errors in opening the software.
It says that the license is invalid as shown in the image below.
Kindly provide solution to resolve this issue.
Thank You!
Error:
Licensing Error
A valid license could not be obtained by the network license manager.
If you are still unable to access a license, contact your system administrator.
Error [0.0.0]
Autodesk Network 2012 Licensing Error Message
Do you think that the builders of the software, the organizing committee worth have built the software for free use of yours? They are out at business and are not to give them at their best, the software to you for your utility. This is easy to say that the software version has to be purchased. You may try downloading trial software that the company may provide you for its trial. The main copy of the software is only available in the market. Thanks to such a system that has proved the builders of a great software to have the full authentication to only the purchaser of the premium software for the sake of the licensed holders.
