Autodesk Revit Architecture 2012 Build Number
Hi Experts!
I just want to ask how I can be able to know my Autodesk Revit Architecture 2012 Build Number.
It was installed on my PC when I purchased it.
Any help will do.
Hi Experts!
Any help will do.
It is very easy to view your Build Number. A few clicks and your ready to go. Here are the steps:
1. Open Your Autodesk Revit.
2. At the top right corner, you can see a "?" mark or "Help" menu. (It depends to your set up if it is a "?" mark or "Help" menu.)
3. Select "About".
4. After clicking about, you can see you build number and what ever update your Autodesk Revit if any update has been made. (The update is located at the bottom of your build number.)
Just easy as that and you can see your build number.
Oriendo Cathon
That’s right. In any application, there is always the “Help” menu where you can find the “About” button or section. In “About”, you can find some very useful information about the program like the build number, version number, name of the developer, email of the developer where you can reach him, copyright year, and the name of the person to whom the program is registered to.
You can also find in there the URL of the website where the application can be downloaded. This is very useful for future downloads so you won’t have to save a note of where you can download the application again in case you need to reinstall. So, to find the build number of your application, launch Autodesk Revit Architecture then click “Help” and then “About”.
You should find the build number indicated by the word “build” or sometimes “b” followed by several number coding.
