Hi!
Revit Architecture 2012 won’t finish installing! It happens at 5 of 9.
I have also read that by removing "ProductInformation.pit" file from the adlm folder so that it would continue, but that has not worked.
Is there another trick that I can do to this process to prevent it from showing this error and complete installation?
Autodesk Revit Architecture 2012.
1: 5 2: adlmPITSetProductInformation failed. 3: 2.
Autodesk Revit Architecture 2012 error
Hey Donal,
Usually this error occurs when there is a issue with the RevitMFC.dll file. As this error is very common, there is hotfix for this. You can download it from here
But before you download and install the hotfix, make sure the build number of Revit 2012 is 20110916_2132. And here is the readme
The readme file has all the information regarding installation and use of this update. For future reference keep that readme file. This should solve your problem.
