Autodesk revit architecture 2013 64xupdate1.exe on my computer not working properly
I installed autodesk_revit_archotecture_2013-64xupdate1.exe on my computer and it worked fine. My co-worker got an error message when he tried to install the same update. What could be the reason? How can I resolve this problem? Any help would be really appreciated.
Thanks in advance.
Installation Error
The Update Release could not be installed because the expected
Autodesk product could not be located on your computer.
Make sure that you are using the correct Update Release for the
Product.
OK
