Autodesk Revit Architecture 2013 installation error
Hello experts,
I am using Windows 7 64-bit Operating System and recently, I downloaded Autodesk Revit Architecture 2013 and 3D Max and installed it but after some time it displayed the following error message. I reinstalled the program so that I may fix this issue but the same error appeared. How can I fix this error? Is there any way to resolve this issue? Any help would be really appreciated. Thanks in advance.
Error 1402.Could not open key:
UNKNOWNComponents47FD3585D4 A569A7 CA8FF7DA5B784536A4
B643700310110409907C5D0680240. Verify that you have sufficient
Access to that key, or contact your support personnel.
OK
