Autodesk Robot Structural Analysis Critical Error
I am facing a big issue with Autodesk Robot Structural Analysis 2009
In rare cases the program provides me this error message:
Unable to load the "psadlmF.dll" library, the program requires reinstalling.
Does anybody know what this is and how to remove it?
I need help please
Unable to load the "psadlmF.dll" library, The program requires reinstalling.
Best Answer by Karla Mahamad
Answered By 35 points N/A #146155
Hello
According to this error report psadlmF.dll file is missing or is corrupted therefore it can't be loaded. This can happen if you have viruses or application have bugs.
As suggested in error report you should reinstall your application, if problem persists then contact application authors and they will help you.
Regards.
Answered By 0 points N/A #199193
To my knowledge common.dll errors are caused by mainly due to the corruption or removal of the dll files which are active library files and carry important information of the operating system.
Also in some cases, these .dll errors can indicate a registry problem, a virus or malware issue. These also sometimes indicate hardware failures.
