Autodesk Simulation 2013 ‘Loads from File’ Error
Posted on - 02/27/2013
Hello
I am attempting to run a linear static stress analysis in Simulation 2013 for several load cases, which was before now accomplished fruitfully in Algor 2011.
Although adding loads to the model through the "Loads from file" option, I exercised the similar ASCII outcomes file (.xyz) that was effectively exercised with Algor 2011. On the other hand Autodesk Simulation 2013 gives me with an error message, which I am unable to examine how to troubleshoot. The error message you can see in the above attached image.
Error No. 13
Error description: Type mismatch
Error source: analyzer
Line Number: 110
