Nomer Ian
Posted on - 12/06/2011
                     Good Day! I am using Autodesk vault 11 and planning to update it to vault 12. I have a problem with 11, while uploading files I got this error. I’ve searched the internet that in version 12 you will not encounter this error anymore, but until now I am using version 11, what can I do to pass remove this error message? Thanks.
Error 0
Operation failed: System error. Please contact your system administrator.
OK
Autodesk vault 11 Operation failed: System error.
Try to check the software if its suitable to your operating system to be sure only and then try to check the software installer if it’s there an error or maybe an corrupted files from the installer just check on that if it’s possible then simply download the error repair tool from the net if it’s possible then try then just upgrade or maybe download the new version of the software and then try to uninstall the software then reinstall again from your system and maybe just simply scan your system there an infected files from your system or the software just simply check on the if it’s possible.
Ben
