Autodesk Vault Basic 2013 error: server not configured.
While trying to use Autodesk Vault Basic 2013, I have encountered the following error message.
It seems  like there is something wrong with my server.
Can some one please tell me how can I configure my server to resolve this error?
Thank you.
The server is not configured to use that feature.
Answered By 10 points N/A #159059
Hello Bersh,
To resolve the problem that you are getting, you will need to download a hotfix that is temporary to that workstation. You can get a hotfix to resolve that issue at the following site: http://www.inventortales.com/2012/04/autodesk-2013-server-not-configured.html
After that you will need to do the following:
  • You will need to extract the DL18674074.msp file and then save it to the temporary directory on your computer.
  • After that you should double-click on DL18674074.msp to install the hotfix.
  • Make sure that you install the hotfix on each applicable workstation that could be having that issue.
Hope this helps.
Carl
