AutoIt error opening application from source
I just installed AutoIt on my PC and I have this error when I want to open the program. Recently I have updated my Windows 7 and I think that could be cause. Can anyone help me please to run AutoIt properly ?
Thank you !
AutoIt Error
Line 9181 (File “C:DownloadsSARDU_2.0.2Beta4sardu_x64.exe”):
Error : Variable used without being declared.
Answered By 0 points N/A #179090
 The solution is the Auto It v3. It was planned for the situations which involve PC rolling out.This is a freeware scripting algorithm which is similar to BASIC . It is designed for the automatic operation of the Windows GUI. It applies a collection of synthetic keystrokes, window administration and mouse motions in order to create an automation of the tasks. You may research more on https://www.autoscript.com/site/autoit
Answered By 590495 points N/A #316958
That error is with the installer you are using which uses AutoIt. Just download the program again and it should fix the problem. For Windows users, download SARDU for Windows. It supports Windows Vista, Windows 7, Windows 8.x, and Windows 10. This link downloads the ZIP file directly from the official website. For Linux users, download SARDU for GNU Linux.
SARDU MultiBoot Creator is designed to help you create emergency rescue CD or USB flash drive. You can use the emergency drive to check and repair your system in case of a system failure. You can save the recovery disk as an ISO file for burning on a DVD disc or create a bootable USB flash drive.
