AutoIt cannot execute external program like this driver. All my drivers are up to date and also most of the programs like Java, Adobe Suite are updated and still not working. Can anyone help me please to fix this error ? Why is not loading properly ?
Thanks !
Error
Driver loading failed. The Utility cannot proceed.
Autolt cannot execute external program
I think what you want to do is to update the BIOS of your Lenovo ThinkPad which is, of course, optional on the part of the user unless the manufacturer requires you to update the BIOS of your laptop. But most of the time this is optional. Though updating the BIOS can be done by the user, it still depends on the model of your computer.
You cannot apply just any BIOS update file on your Lenovo laptop even if the BIOS update file is designed for Lenovo computers. Installing the wrong BIOS update file on your computer will damage your machine and the BIOS might function incorrectly. Before installing a BIOS update, make sure to check if the file is designed for your computer model.
To properly update your computer’s BIOS, download and install Lenovo ThinkPad BIOS Update Utility. This BIOS update utility supports the following models: T60 and T60p wide screen models [machine types: 6369, 6370, 6371, 6372, 8741, 8742, 8743, and 8744]. It requires Windows 2000, Windows XP [Home or Professional], Windows Vista, and Windows 7.
