Automated exchange 2010 edb recovery possible or not?
I’ve Exchange 2010 SP1 and faced a problem, but have no backups. I was wondering how to perform automated exchange 2010 edb recovery?
I wish you explained it much further so we can fully understand the whole situation and to know what exactly is happening with your Microsoft Exchange 2010. But anyway, if this is the first time that this happens, try restarting your machine then try it again. See if the result is the same after a reboot. Since you are asking on how to do an EDB recovery, I’m not sure if it is still possible with your present situation since just like what you said you don’t have any backups with you. Any recovery tasks that an application do requires a certain backup copy of the system from which it will be restored from.
Just try reinstalling the program to try fixing the problem. Uninstall Microsoft Exchange 2010 then restart your machine. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the program back then see if you are now able to use it.
