mhakair5
10 points
Posted on - 05/12/2012
What are the steps to do when you like to stop Automatic Capitalization in PowerPoint 2007?
Hi!
One of the cool features of Office 2007 is the automatic capitalization of words in necessary places.
But Microsoft has also given users the liberty to tweak or completely disable the feature.
Please follow the steps to do so:
Start PowerPoint 2007.
Click the circular office button in the upper right portion of the window. A dialog box appears.
Click ‘Word options’ from the bottom right corner
From the left, choose ‘proofing’. Then click the ‘autocorrect options’ button. A dialog box appears.
Choose the ‘autocorrect’ tab. Here you can see several autocorrect options related to automatic capitalization such as “capitalize the first letter of sentences”; “capitalize the first letter of table cells”. They are checked by default. Just uncheck the ones you want then click ok.
I understand that you want to know how to "Stop the Automatic Capitalization in PowerPoint 2007.
Good to know that we have a way on how to do that and below are the steps to follow in stopping Auto Capitalization in Power Point 2007:
First you have to click Tools and then Auto Correct Options;
The next thing you have to do is select the Auto Correct tab if it's not currently selected;
And then remove the check mark from the option Capitalize first letter of sentences;
Finally click the OK button.
You're good to go once you followed the steps, any new line of text won't be corrected to begin with a capital letter.
Good luck and have a great day!
Hai Mhakair5,
To stop the auto capitalization in PowerPoint 2007 please follow the instructions below.
First of all Click on the Office button in the top left corner of the screen.
Then Click the PowerPoint Options button at the bottom of the window.
Then Select Proofing in the list of options.
Now Click the AutoCorrect Options button.
Uncheck the option Capitalize first letter of sentences.
Click the OK button.
I hope now your problem has been solved, if not please leave a reply.
Regards.
Hi
It is quite an easy fix in the Automatic Capitalization (Auto Correct) feature of PowerPoint 2007. For more information visit this Techyv link too : How to Stop Capitalization in PowerPoint?
