Steve Gates
Posted on - 07/07/2011
Automatic changing of my browser homepage
My browsers automatically change its homepage. I tried to change the automatic homepage set on my browser to https://www.google.com/
but all of the sudden after applying the changes and I press the home button on my browser, it doesn’t load the google.com and upon checking of the default homepage the default homepage is not that I have put in. How to disable automatic changing of home page?
I have several web browsers installed on my computer but I haven’t used one that randomly changes the default home page. Popular web browsers like Google Chrome, Opera, Mozilla Firefox, and Microsoft Internet Explorer starts with a fixed home page. You can always change the default home page any time you want but the browser will never change the home page by itself.
If your browser doesn’t save your selected home page, a file is probably corrupt. Try to uninstall and reinstall the browser or install the latest version. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller and select the web browser in error among the applications then click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system. When it is finished, restart your computer and install your web browser back.
This should fix the problem. These are the latest versions:
If you want to convert CCleaner to Pro, download the codes and follow the instructions.
