anonymous
7060 points
Posted on - 05/23/2012
I am playing chess in www.gamezer.com site I when suddenly I am being logged out automatically while in the middle of the game. It happens with no particular length of time. Is there any set-up in my computer that I need to adjust? What is the solution to this problem?
Automatic log out from the website
Make sure you don't get into the site and into its forum at the same time. If this is not the case, update your flash player by following the instructions below.
1. Uninstall your current flash player by going to control panel, then programs and features . Click Adobe Flash Player then choose uninstall.
2. Download the latest Adobe Flash player here get.adobe.com/flashplayer.
3. Run the exe file then finish the installation.
If it does not resolve the problem, try using a different browser like Opera or Mozilla Firefox. Moreover, download a latest version of Java here java.com/download.
