Automatically resize forms depending on the resolution of the screen
10 points
Posted on - 08/13/2011
Hello!
I am working on a project and I realized that it contains a set of forms on a screen resolution of 1920 * 1080, but I would want to move to a screen resolution of 1280 * 820.
Please, suggest a solution on how I can code or do some programming to automatically resize the forms according to the resolution of the screen.
Thank you in advance.
