shbana.peno
Posted on - 10/01/2011
I am very fond of video games but I normally face a problem to quench my thirst of playing games.
Whenever I install and play a heavy size strategy game like commando, MOHA, Need 4 Speed etc, my screen resolution changes automatically (icons become larger) and I have to change it back manually to normal view size.
What should I do to remove this problem?
Automatically shifting in Resolution while playing strategy game
When you are playing games, the settings of the game becomes the setting of the computer for the meantime and then it should turn to the default settings before you run the game. In your case, it must be that when you exits you game.
It doesn't necessarily stops already. You can see this in the Task Manager the on the Process Tab. Look for the process that corresponds to your game then end it there.
You cannot rush the closing process without going into Task Manager unless you have a high caliber PC.
Hope this solves your problem with your PC.
