Automation Error When Opening Word
Hello techyv users!
I have application set up that designed with another software programs, as well as Word. I eliminated the application because it was enjoying up the computer with issue information. Now the application was eliminated, but each and each time I begin MSWord any files in that program I get one idea "Could not generate PLMSWord. PL Word Error = -2147024770 Automation error. The particular component could not be discovered." This component from the software that was removed. How will I reconfigure Concept to create the problem concept moving away? Also shown when I end the program or Concept software and need to press on the "x" to end display twice to make the software shut.
Thanks for any help you can offer.
