Automation facility applied in wallpapers
Maybe you are talking about an application that automatically changes your desktop’s wallpaper. Yes, there are applications that work that way and one of them is Wallpaper Changer. This is a very small program that automatically changes your desktop’s background wallpaper depending on the setting you selected.
You can set this program to change your wallpaper on a timely basis, every time you start your computer, or maybe once a day. You can also set it to manual which means the program will not change your desktop’s wallpaper and you will do it manually from the program. The user can also set it to monitor a particular folder that contains different images that is set to be used by the program in changing the background wallpaper. Setting it to monitor a directory will create its own database and updates it automatically every time an image or images are added or deleted from the folder.
It’s an old program but still quite useful. Wallpaper Changer was last updated on May 23, 2009 and its last version, Wallpaper Changer v1.91b2, works on all Windows versions. You can download this little program by visiting http://www.chip.de/downloads/Free-Wallpaper-Changer_24033837.html
