The AV splitter Latest Version
I heard that this AV splitter is a tool that support wide variety of video format. Does it allows me to customize the playback of DS Meddia Player?
AV Splitter is a multi-format video tool to demux the most popular format media files. This was built based on connection management of registered and unregistered media formats depending on playback content. Using this AV splitter you can easily customize media player, media center and other famous media players. At present this tool is available only for windows systems for both 32bit and 64 bit systems.
Latest version of AV Splitter is 1.2.2.8 which is a stable version. Beta version is 1.3.0.7
There are other most popular splitter tools which can also be used for the same purpose as above mentiond.
Hello David,
The AV Splitter is a multi-format DirectShow media splitter that will help you demux popular sorts of media files. It has got built-in fine-tuning as well as connection management of unregistered and registered media filters. That is based on the type of content playback.
With this Splitter, you can be able to easily customize the playback in media players, for instance the Windows Media Player, the Windows Media Center as well as Media Portal, and many others. I suppose the DS Media player is one of those supported too.
Carl
Notifications
